Power steering assist is marginal
Looking for where to test steering pressure, and where to locate/ adjust relief valve. Thanks-
S80XL
D004D008877X
4.3 GM
  • Posted 6 Jan 2022 13:32
  • Modified 6 Jan 2022 13:33 by poster
  • By ForklifttSteve
  • joined 13 Nov'19 - 28 messages
  • Mississippi, United States
Steve Pierce
Coast Equipment Services
Excellent. Thanks Fishmech-
  • Posted 14 Jan 2022 14:13
  • By ForklifttSteve
Steve Pierce
Steve,
Steering should be at 1400 PSI. there should be a test port at the steer valve. You can test at the steer line for a very short time. The hydraulic pump has a priority valve installed specific for the steering. May need to start there. Also, the return line from the steer valve goes to the brake assist. The problem could be the pump or the steer valve. Hold the brake down and see if it is easier to turn. Good Luck.
  • Posted 14 Jan 2022 05:58
  • By Fishmech
  • Virginia, United States
Taylor XC300M
New - Sale & Hire
SMV (Konecranes) SL37-1200A
Taylor XC300M
New - Sale & Hire
