No Start
This has the impco Tier3 fuel system. Truck has good spark, but will not start. Lock off is opening. I am not familiar with this system and I think it's fuel related.
  • Posted 5 Dec 2021 08:25
  • By forkmen123
  • joined 5 Jun'12 - 50 messages
Kevin
also check the LP filter.
and make sure the hose fitting to the tank is all the way home.
we have seen several tank fittings not letting the valve open on the end of the hose..
common issues on LP fork trucks.
have you tried to manual purge the demand regulator?
there is a button on the unit for prime.
you should hear a hisss when the button is depressed.
from there check the spark and spark time with a time light.
and check the compression.
if it is over 10 years old
check the time belt.
if it is cracked, replace it asap.
it might be broken.
these engines are basic.
fuel, air, spark
  • Posted 26 Dec 2021 05:52
  • By iowagold
  • joined 7 Jan'20 - 14 messages
  • Iowa, United States
Thanks Paul in Iowa
http://www.poustusa.com
I read your problem are you sure the lock is feeding fuel to emco converter could be stuck internally. on primary side of converter you will see a plug approx 3 /8 this is were you check the primary pressure you could open and if you don't hear gas lock is not opening if you have a gauge you could see if you pressure
  • Posted 5 Dec 2021 11:19
  • By Scott_
Scott
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Ice 24INCH-AUTO-SCRUBBER
USD6,396
USD1
USD6,396
