Error 53
Machine model XE18 gives error 53 on the screen. Travel and hydraulics do not work. Can you help on the subject?
  • Posted 29 Sep 2021 19:59
  • By Seyit_AKCAN
  • joined 20 Aug'20 - 5 messages
  • Turkey
SEYIT AKCAN
hola la alarma 53 es que tienes activada una de las palancas activadas en el momento de contacto..
solucion.....desconecta una por una las palancas y se quitara el error cuando desconectes la que esta mal..
tambien si tienes consola ZAPI ajusta las teaching hidraulico
Littoral translation - hello alarm 53 is that you have activated one of the levers activated at the moment of contact..
solution.....disconnect the levers one by one and the error will be removed when you disconnect the one that is wrong...
Also if you have a ZAPI console adjust the hydraulic teaching
  • Posted 12 Dec 2022 00:38
  • By manolo
  • joined 12 Dec'22 - 6 messages
  • Spain
tecnico
Hydraulic function command entered before ignition.
(Except for hydraulic steering).
  • Posted 29 Sep 2021 21:39
  • By andrew_k
  • joined 17 Mar'07 - 339 messages
  • England, United Kingdom
Toyota 8FD45
Maxlion FD50T
Yale Lift Truck Technologies
