Engine accelerates and quits
When driving this unit around it will all of the sudden rev the engine up a little bit and then the engine quits. Will start right back up and might do it again 15 times in a row or wont do it again for a couple hours. I have only had it shut off on me once and all the other times it was on the operator. So every time the operator calls me to look at it, it works fine. Checked all the connections on the sensors on the throttle body. Didn't see any rubbed through or corroded. We actually have 2 combi units that do this same problem. Really intermittent. Sometimes go away for months. Any help is appreciated. Thanks
Here is the model and serial of both units.
CL70055LA00 serial 8614
CL20100LA47 serial 7982
  • Posted 23 Sep 2021 23:50
  • By Roling
  • joined 21 Jan'21 - 5 messages
  • Iowa, United States
Go motor
  • Posted 27 Sep 2021 23:36
  • By Roling
What engine is in this unit VW or GMC
  • Posted 27 Sep 2021 22:57
  • By forkliftpete
  • joined 19 Nov'14 - 24 messages
Pete
Hi Roling.
Combilift Technical Support is free. No contract etc required. The web site is always open.
Thanks,
Richard
  • Posted 24 Sep 2021 17:44
  • By Richard_Irwin
  • joined 20 Feb'20 - 81 messages
  • Monaghan, Ireland
Thanks for the information. I will try and contact Combilift. I figured you had to have a service contract with them to get information out of them. Thanks
  • Posted 24 Sep 2021 05:45
  • By Roling
Hi Roling,
I think these older LP Trucks have GM IMPCO Engines. The faults seems to be an electrical issue, most likely a loom short. Combilift North America team can be contacted by email or phone. I can't add an email address here but it is service.usa followed by a @ and then Combilift.com.
Alternative go to the combilift web site and scroll to the bottom and select Technical Support.
Hope this helps.
  • Posted 24 Sep 2021 02:50
  • By Richard_Irwin
  • Monaghan, Ireland
UN Forklift FB25N1QZ1
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
