Hi,
the display is off, there is NO driving forward/back , NO lift , only the steering wheel works. What can be problem?
Thank you in advance.
Dragan
hi dear i have the same issue with linde r16 i wnat to know ho do fix it
thanks
oke , if you sure the 24 volt system are oke , you have power on dash and all controller. If not going on dash defect , but i think not.
Hi,
that is not problem, I tried, where can I purchase electric schemas for this forklift truck?
Thank you in advance,
Best regard Dragan
Hi,
Best regard Dragan
Check first 24 volt converter and circuit. Cooling fan drive motor defect , disconnect the fans and look converter on armrest have 24 volt , green led lights up. dash board shows always lights and clock time , when not 24 volt error i think
look for fuse or camcus problem
Hi,
serial number : G1X115L01728
2000. year
Thank in advance , Dragan
