Won't move after Access3 swapped
Had to swap an Access 3 module out on an RR5200. After getting everything put back together it will not in any direction now. Am I missing something on the setup? This is the first time swapping one of these out before
  • Posted 25 Jul 2021 23:16
  • By gtptim2007
  • joined 27 Aug'17 - 14 messages
on this model the access 3 contains the software, so you dont need to update other modules
assuming your new access 3 is installed correctly, are you getting any fault codes
is this a new access 3 or known good or unknown condition
have you completed the features section or as mentioned copy from access 2 to 3, assuming same software version
  • Posted 27 Aug 2021 17:42
  • Modified 27 Aug 2021 17:44 by poster
  • By crownie
  • Victoria, Australia
did you copy your set up from the old access into access 2, then copy from access2 back into the new access3? you can do this in the utilities menu.
  • Posted 26 Jul 2021 23:20
  • By JMC1
  • joined 8 Nov'18 - 50 messages
  • Iowa, United States
Did you dowload/update software? Normally after you swap an access module, you have to download software so all modules can talk to each other and have the latest software.
  • Posted 26 Jul 2021 02:53
  • By marcos_m
  • joined 25 Feb'19 - 114 messages
Thanks
Deborah Baker Deborah Baker
