Won't Start
Hi All.
I have an issue where my forklift won't do anything. When I press the brake, horn or turn the key just get an alarm and no lights on the dash.
What is likely to be causing this. Have good voltage have checked all the fuses. It is in neutral and have tried moving everything around.
Thanks Dan
  • Posted 22 May 2021 12:54
  • By Daniel_Wilson
  • joined 22 May'21 - 3 messages
  • New Zealand
Spot on thanks
  • Posted 24 May 2021 05:17
  • By Daniel_Wilson
  • New Zealand
I haven't tried that. It maybe the ignition switch but it hasn't been a problem. The lights on the dash don't come on so don't think it is starter related. It feels like there is a switch not made somewhere that is stopping it.
  • Posted 23 May 2021 18:14
  • By Daniel_Wilson
  • New Zealand
I'm not very familiar with toyota, so I'll help you as much as I can.
Have you tried swapping the Starter Relay with another relay that does not prevent the engine from starting ?
Is the ignition switch worn out ?
  • Posted 23 May 2021 18:02
  • By LaGrange
  • Missouri, United States
Strong in mind, Strong in Health.
bad earth
  • Posted 22 May 2021 20:38
  • By andrew_k
  • joined 17 Mar'07 - 338 messages
  • England, United Kingdom
SMV (Konecranes) 16-1200C
SMV (Konecranes) 16-1200B
Sue Tomic Sue Tomic
