Fault code's
I do look for explain fault code,s of Crown wave 60-118
Fault code 327 and 216
I have no doc of it.
Regards,
TraigoGen
  • Posted 8 May 2021 17:26
  • By TraigoGen
  • joined 2 Jan'20 - 12 messages
  • Netherlands
knowledge about Toyota - BT
Event Code 216
The driver of the main contactor coil is shorted.
All vehicle movement is disabled.
Step 1: Check if there is a short or a low impedance
pull-down between NLC (CA403-6) and -BATT.
* If: There is a short or low impedance
- Then replace the wire
* If: There is not a short or low impedance
- Then replace Access 2/3
Event Code 300 through Event
Code 352
These event codes match Event Code 200 through
Event Code 252.
Step 1: Follow the procedures for the corresponding
event codes; for example, for Event Code 310, follow
the procedure for Event Code 210. If the procedure requires
the checking or replacement of an Access module,
then check or replace the Access 3 module. If the
procedure references the right traction motor, do the
same checks, but for the left traction motor.
Event Code 227
The lift switch is pressed when the vehicle is
turned on.
Step 1: Release the lift switch.
Step 2: Check the lift switch contact.
Step 3: Use a DVOM to check the signal value on the
Access 4 connector.
* If: There is a mismatch between the values in input
and the values read
- Then replace the Access 4 module
  • Posted 10 May 2021 17:20
  • By ivanlinaric
  • joined 16 Jan'11 - 110 messages
  • Zagreb, Croatia
Service technician.
Feel free to contact me at ivan.linaric@okretnimoment.hr
