Mitsubishi FB16KT dash
customer has a truck that when ignition is turned on the hour meter shows 'DEAD' for all motors.
after checks it then shows time correctly.
all lights and BDI work fine, truck works perfectly.
Just no hour meter reading
anyone seen this before?
can it be repaired or does it need new display?
thanks in advance
  • Posted 28 Mar 2021 08:24
  • By ian_h
  • joined 11 Sep'08 - 149 messages
  • United Kingdom
if i can help i will.
For the trucks we've had to deal with, the battery is actually part of a chip on the board. It's a Dallas DS12887. Sometimes, it's under an aluminum enclosure (have to carefully cut off) It's usually the biggest thing on the board. You have to be good with a Dremel and a soldering iron if you wanna tackle this job.
Here's a video explaining how to repair the chip. Note that you will have to remotely mount the battery holder somewhere other than suggested because there's not room above the chip with the housing assembled.
https://youtu.be/NdlSfqto_0o?si=WV6f_aKNlFUqNVDJ
One more note, you can buy new chips on their own, but they've not been manufactured in years, so you are counting on a battery that is several years old.
  • Posted 23 May 2025 03:03
  • By ForkliftAmerica
  • joined 3 Aug'12 - 38 messages
  • Missouri, United States
I dont have any display available right now but its like example cr2330. You should see it after you open the display. (Displays circuit board)
  • Posted 17 May 2025 23:58
  • By Justus
  • joined 23 Aug'20 - 37 messages
  • Finland
Thank you for the reply.
Do you know where it is located inside the dash?
I opened it, didn't find any battery.
If you have some pictures or information of it, please send it if you can.
  • Posted 17 May 2025 23:53
  • By geert_vosters
  • joined 22 May'24 - 5 messages
  • Netherlands
Gevo Machinery B.V.
There is a little battery inside the dash. Replace the battery, it will solve the problem.
  • Posted 17 May 2025 23:17
  • By Justus
  • Finland
I have the same problem, did you solve the problem?
  • Posted 17 May 2025 22:05
  • By geert_vosters
  • Netherlands
Gevo Machinery B.V.
battery in dash are dead.... try to replace it , it is a lithium cell i mean
  • Posted 8 Apr 2021 04:52
  • By tr_doctor
  • joined 4 Dec'20 - 186 messages
  • Netherlands
Regards
Hi Justus,
thanks for reply, that was one of the first things i looked at, all wiring is good.
i have since been told that there is a battery in the display which holds information, i have yet to strip & have a look
  • Posted 6 Apr 2021 03:15
  • By ian_h
  • United Kingdom
hour meter info comes from logic card so check wiring first between logic-display. problem cause is possible in logic card too.
  • Posted 3 Apr 2021 04:31
  • By Justus
  • Finland
Mitsubishi FGE35AT
Ncn 110TH
Ncn 110TH 2015
Combilift Ltd
