rough running
forklift runs only when you hold down throttle all the way down. Then it only stay running for a few sec. will rough low idle. Does anyone out there know where i can find a relay location on a G25E-3.
  • Posted 6 Feb 2021 03:12
  • By Robert_Coleman
  • joined 6 Feb'21 - 2 messages
It runs the same way on gas as lp
  • Posted 9 Feb 2021 07:45
  • By Robert_Coleman
They only relay relevant to the fuel system (propane and/or gasoline-not sure what you are running) is the fuel lock off relay that would power the solenoid for fuel lock off. If you are running propane check the LP converter and mixer. In some cases the mechanical part of the fuel lock-off valve when running propane or LP will malfunction. Not sure what fuel system you are running..
  • Posted 8 Feb 2021 19:54
  • By Speedfreak
  • joined 24 May'18 - 103 messages
  • Niederlande, Netherlands
Oxford Ct, United States
Esie Cortez Esie Cortez
