Event code 226
The forks goes up very slow and also it goes down very slow.
The lift pump motor rotates very slow on both directions.
the 3 phase cables from access 2 to pump motor heating up.
What could be the possible cause?
  • Posted 4 Feb 2021 07:17
  • Modified 9 Feb 2021 22:10 by poster
  • By RamKhudan
  • joined 4 Feb'21 - 54 messages
  • Curacao
Ram
ramkhudan@gmail.com
I checked cooling fan, the fan run good
I checked all the connections, all good
  • Posted 6 Feb 2021 06:16
  • By RamKhudan
  • Curacao
Ram
ramkhudan@gmail.com
I checked the battery condition
All are good, voltage are good under load
  • Posted 6 Feb 2021 06:11
  • By RamKhudan
  • Curacao
Ram
ramkhudan@gmail.com
Check battery condition, water level, and voltage under load
  • Posted 5 Feb 2021 06:41
  • By Triggs
the lift going up and down very slow
also the lift pump motor rotating very slow
the 3 cables to the pump getting hot
access 2 heats up and the code 226 sets, after lifting the fork for a minute or 2
  • Posted 5 Feb 2021 03:46
  • By RamKhudan
  • Curacao
Ram
ramkhudan@gmail.com
could be cooling fan not running, or loose connections building heat. you can check fan operation in accessories menu
  • Posted 5 Feb 2021 03:19
  • By JMC1
  • joined 8 Nov'18 - 50 messages
  • Iowa, United States
