cat teir 1
I have a cat teir1 that has kicked a few butts around here.
runs like a champ has 160psi +- 15.Has had vaporizer carb governor plugs wires cap rotor ecu trim valve fuel lock
all changed because it hiccup's during acceleration every now and then.Runs for 45 min then it happens runs 10min then again.Sprayed brakeleen around looking for vac leaks none found.Now if you take the hose to the breather tube lose it'll run like a champ.Has been plugged in and all settings close to normal.All parts from this truck are on a separate truck and it runs fine.Besides burning it to the ground any clues?
  • Posted 30 Sep 2008 22:11
  • By proshadetree
  • joined 23 Feb'06 - 484 messages
  • Tennessee, United States
Found it today a small lip in the hose from vaporizer to breather tube.Flapped over at times and would run lean. hope this keeps someone from pulling their hair out cause in now bald.
  • Posted 2 Oct 2008 05:35
  • By proshadetree
Libiao Robotics
