Lift problem
Hi
We have a strange problem with the above truck, F001 H2.0FTS, it is fitted with the mini levers
It will only lift if you rev the engine, tilt and sideshift all work on tick-over
Tried swapping the lift/lower wires over on valve block, problem swapped to lower, ie needed to rev the engine to lower lifts ok on tick-over
Tried swapping mini lever box onto another truck all worked ok
Any suggestions
PS think this truck has had this problem for a while but is masked by the fact that drivers get used to revving the engine to make it lift quicker normally
  • Posted 17 Nov 2020 02:40
  • By P_E_G
  • joined 30 Jan'13 - 78 messages
  • Kent, United Kingdom
paul(at)gandgforklifts(dot)co(dot)uk
Just for any other persons information
Checked lift/lower valve output though the dash display, found 0.805 amps on lift, 1.130 on lower at tickover
Recalibrated mini levers although we had tried this numerous times before seems to have cured the problem
  • Posted 17 Nov 2020 22:28
  • By P_E_G
Terberg RT223
Toyota 8FD45
Terberg RT223
Toyota 8FD45
Lift Technologies Inc.
Deborah Baker Deborah Baker
