D156 code with Motor temp and electronic control indicators lit
D156, lift was in limp mode. After Linde tech had tried to troubleshoot and connect with their software, it was determined that the wiring harness had an issue. Ordered wiring harness and installed in lift, lift had the same code. Linde tech came out a second time and still could not connect. He recommended replacing truck control module, Replaced it, still same code, then we replaced the display module. Lift operated for about 10 minutes and coded out again, with the same indications.
Any assistance would be great.
  • Posted 15 Sep 2020 00:17
  • By Glen_Clark
  • joined 15 Sep'20 - 4 messages
GclarkSS
Did you ever manage to solve this? as I have he same problem, any help would be appreciated. Thanks
  • Posted 18 Sep 2024 20:28
  • By Richard_Jackson
  • joined 18 Sep'24 - 1 message
  • United Kingdom
it is a error canbus. Mostly comes you activate a electronic part in software but not really connect or install it in truck. Canbus looking for this part but can not find it... possible FDE LFM activated but not in truck
  • Posted 21 Feb 2022 05:42
  • By tr_doctor
  • joined 4 Dec'20 - 186 messages
  • Netherlands
Regards
71 / 5.000
Vertaalresultaten
I'm sorry you are so far away would have liked to look for this problem
  • Posted 20 Feb 2022 20:47
  • By michel_v
  • noord holland, Netherlands
Check the ignition switch. I had a similar case with a damaged ignition.
  • Posted 11 Jan 2022 08:51
  • By tomason2
  • joined 5 Apr'15 - 53 messages
  • Poland
serwiswojnarowski@gmail.com
D156 is a heart beat error
(Canbus) this is why he can not connect
May be a controller issue or display
Can resistors are in display or the ldc controller
  • Posted 3 Dec 2020 19:12
  • By Lindetech
  • joined 27 Mar'16 - 131 messages
  • Auckalnd, New Zealand
The can bus failed the connection was never established.
  • Posted 6 Oct 2020 04:45
  • By Glen_Clark
GclarkSS
When the linde tech was there they should have connected and looked up all the codes present. Without the software there isn't really any other way unfortunately
  • Posted 5 Oct 2020 21:15
  • By Jt_Ng
  • joined 5 Oct'20 - 18 messages
  • Victoria, Australia
The only code is what was described. Not able to access any other code. Is there another way to get codes? Don't have access to the linde diagnostic software.
  • Posted 5 Oct 2020 20:47
  • By Glen_Clark
GclarkSS
Is that the only code that's coming up? I can pretty much guarantee that there should be other codes also. You should have a few T and L codes in there as well
  • Posted 5 Oct 2020 20:36
  • By Jt_Ng
Crown RD572513TT6860R
UN Forklift FBT18NQZ1
Deborah Baker Deborah Baker
Libiao Robotics
