NR14K hydraulics slow
We have a customer with a CAT NR14K reach truck, 2003.
Firstly the lift went slowly, now reach also slow.
No fault codes on dash at all, but drive motor wiring is burnt (from Zapi to motor), not hyd motor wiring. Help would be appreciated
  • Posted 26 Aug 2020 02:36
  • By steve_i
  • joined 22 Oct'09 - 11 messages
  • county durham, United Kingdom
Thanks, Justus. Usually they do give error codes, but the toyota we had should have too and didn't, so maybe this could be the same.
  • Posted 27 Aug 2020 00:47
  • By steve_i
Yes there is a encoder bearing but it should give a error code.
  • Posted 27 Aug 2020 00:37
  • By Justus
  • joined 23 Aug'20 - 37 messages
  • Finland
Thanks, but don't think so. Battery is definitely not the worst we have seen, voltages and gravity ok, connectors ok. Truck drives well too, despite the wiring issue. Is there a speed sensor bearing on the lift motor? We had a toyota recently with a drive motor sensor bearing fail, this didn't show a fault, but drove very slowly.
  • Posted 27 Aug 2020 00:20
  • By steve_i
bad battery?
  • Posted 27 Aug 2020 00:14
  • By Justus
  • Finland
Mitsubishi Logisnext FD25T5M
TCM FHD105Z
