Error 21 Wiring Diagram (Damaged Loom)
Hello,
I've a 2004 GP25N displaying error E-21, I've found out that the error is for the air flow meter signal, after further investiagtion I've found that the wiring too the sensor has been damaged (eatten by a rat) I've placed an order for a new Air Flow Meter but unfortantly due to the damage there is no plug on the loom and I need to make a new loom too plug in but im unclear as too which cable is plugged into which pin on sensor.
If somebody is able too send the diagram over I will be massively greatful
Truck Details
GP25N
ET17DL-0650155
2004 YOM
  • Posted 14 Jul 2020 01:31
  • By Lordmoss13
  • joined 3 Jul'20 - 16 messages
  • Wales, United Kingdom
figured it out yet?
i found some info on this that might help
1- looking at the plug it is a flat 5 terminal plug with a locking tab on one side, if you lay the plug down flat on a table with locking tab on top the terminal layout goes from left to right 1-2-3-4-5.
terminal 5 wire connects to terminal 119 of ecm or bridged in harness wire that connects to 119.
terminal 4 wire connects/bridges to terminal 1 at connector (terminal 1 connects to ecm terminal 67.
terminal 3 wire connects to ecm terminal 51
terminal 2 wire connects to ecm terminal 34
terminal 1 wire connects to ecm terminal 67 (bridges to terminal 4 on plug)
The diagram i'm looking at does not show any wire colors unfortunatly.
  • Posted 16 Aug 2020 04:13
Kalmar DRF450-70C5XS
Aichi SR18A
GemOne
