controller box does everything except forward motion.
Hi there, so the control box i've been working on has been rebuilt because several parts were broken. everything has been repaired, the only problem is that it won't move forward. left, right, back, up and down all operate. if anyone has run into this issue, or knows some tip or advice please pass it along.
  • Posted 3 Jul 2020 03:39
  • By Steven_Romp
  • joined 3 Jul'20 - 1 message
Hopefully you fixed your problem, but if not, did you try your box down on the bottom plug? That would eliminate your control cable. Then I would check your drive selector switch. It may be wired wrong.
  • Posted 30 Dec 2020 15:03
  • By Scissor_God
  • joined 30 Dec'20 - 26 messages
Scissor God
Shadow722@live.com 209-846-5836
Sue Tomic Sue Tomic
