Code G2
Turn key switch on and goes through self test ok. Step on dead man pedal and code appears. Lift/lower works but not drive or steering.
  • Posted 19 Jun 2020 04:29
  • By techtrnr
  • joined 2 Jun'10 - 8 messages
Pueden ser dos cosas,el sensor o arnés abierto(cable roto que a simple vista lo se aprecia...).saludos!!
  • Posted 6 Feb 2021 00:24
  • By lorito
  • joined 15 Aug'20 - 10 messages
  • Mexico
alex
Most likely steer feed back pot, or prox sensor
  • Posted 4 Feb 2021 07:18
  • By 1sharpdog
  • joined 20 Apr'12 - 220 messages
David Sharp
Have a Great day and thanks for all the great advice! sharpforklift@gmail.com
Debe de ser un circuito abierto del arnés..
Literal translation...It must be an open circuit harness.
  • Posted 5 Sep 2020 06:10
  • Modified 5 Sep 2020 08:45 by administrator
  • By lorito
  • Mexico
alex
Does the steer wheel auto center when you step on the deadman pedal? If not, the gear shaft at the bottom of the steer motor may be sheared off on top of the gear. Seen it a few times.
  • Posted 5 Sep 2020 04:29
  • By LiftGuy
  • joined 5 Sep'20 - 1 message
  • Virginia, United States
Briefs United States
VETTER Industrie GmbH
