slow travel both directions
hello everyone, needing help on a 7HBW23 S/N 26246 Unit is running slow. i began with hooking up a curtis handset to the controller. throttle percent wide open shows 20% if i change the parameters to full speed on p 01 thru p4 it shows 40% wide open then of course runs a little faster. replaced tiller card and had toyota program card. with the new card installed i get the same results. the handle harness is new also. wiggled wire harness to the controller and nothing changes. What could problem i though the card would fix it.
  • Posted 29 Apr 2020 02:57
  • By Hdsprt
  • joined 12 Nov'15 - 43 messages
  • Illinois, United States
VETTER Industrie GmbH
Enforcer FLBAXT25
Nagano NUL120-6
