carraige drops out of sequence under load
I have tried different velocity fuses in the primary and secondary lift cylinders and it is better but with a max load the secondary rails still stay as the carraige drops. Any ideas?? thx-Troy
  • Posted 13 Sep 2008 23:45
  • By troy_m
A-Lift Services -- safe -reliable -affordable
clean and grease the mast channels esp if they are new and dry (light coat dont gob it, too much grease will make the rollers slide not roll)
look for bad rollers, ball bearings can fall and stop the mast up by getting stuck between another roller and the channel
the load may be adding friction to the assy
ive had to grease many a mast cause they wouldnt collapse in sequence
  • Posted 17 Sep 2008 23:09
  • Modified 17 Sep 2008 23:15 by poster
  • By justinm
It is an older Yale but it's fairly clean and low hours. No work has been done to the mast lately but I'll check to make sure it's well lubed. It only seems to drop out of sequence under a heavy load -strange eh.
thx -Troy
  • Posted 17 Sep 2008 06:06
  • By troy_m
are the channels clean and straight. how old is this truck. has the upright just been repaired maybe shimmed too tight.
  • Posted 17 Sep 2008 04:49
  • By kevin_k
VETTER Industrie GmbH
