confused!
Unit will crank and start but no action. hydraulic controls doesnt work and drive and reverse doesnt work.
  • Posted 26 Mar 2020 02:32
  • By Duane_Carroll
  • joined 26 Mar'20 - 16 messages
Thanks man! I will dive into it in the morning. That icon on the dash is indeed lit up. Haven't had a second to troubleshoot it any further but will let you know. I suspect you're right sir!
  • Posted 26 Mar 2020 11:22
  • By Duane_Carroll
look on the display when you crank the truck and try and drive it and tell me if the far right icon light with the forks/updwnarrows/slashmark is lit up? Also is the neutral indicator on the left side flashing?
If you see these indications then the seat switch circuit is not working.
The operator presense system is not activated and the truck does not see you on the seat with the seat belt buckled.
Check the wiring going to the seat, the connector is under the hood on the RH side near the hinge area, it goes across underneath the hood sound insulation and comes out through the hood and runs under the seat on the LH side, it connects to the seatbelt and also to a switch mounted under the seat cushion. There are a couple of screws accessible under the front side of the seat, remove those and you can remove the cushion and inspect the wiring and seat bracket assy.
I've repaired many of these because the wiring comes loose and as the seat moves up and down the wiring gets damaged. Also at the connector under the hood it can get damaged there also.
  • Posted 26 Mar 2020 08:20
Mitsubishi FD200
Toyota 4FD240
Noblelift
Mitsubishi FD200
Toyota 4FD240
Kai von Berg Kai von Berg
Mitsubishi FD200
Toyota 4FD240
