anyone point me in the right direction with intermittent drive fault to reverse?
truck runs ok, then when you select reverse, warning lamp next to low fuel (looks like round gear with warning triangle inside) lights up and truck wont move either way.
turn off and re-start and everything works ok for a while.
only ever faults when selecting reverse.
sometimes wont fault all day, then faults every time reverse is selected.
i was thinking it may be pot to accelerator, but why only reverse
Hi, we have exact same fault. Did you find what the problem was? And manage to get fixed?
Any help much appreciated
Thanks
cheers alan,
truck only done about 800 hours so oil not been changed yet.
ill have a look at solenoids when i service truck next week.
Hi Ian
This is a hydrostatic truck. The light you are talking about is an error light. You need a hand held terminal to check the error. It may be that the solenoid is sticking. When did you change the hydraulic oil as it uses the same oil for drive and lift.
