error t555
Hello we have a linde 386 and gives error t551, no current sensor detected on the truck althought a current sensor is registred.
Which currents sensor is , i do not know what to check?
  • Posted 22 Jan 2020 03:12
  • Modified 22 Feb 2020 19:12 by poster
  • By daniel_a
  • joined 14 Mar'13 - 121 messages
  • ARGES, Romania
Your current sensor is faulty. There is a couple of things to test. Test you have 13v supply to the current sensor and also your canbus system is correct and intact to the sensor. I have just had a faulty one recently, if you do have LSG or pathfinder you can turn off the sensor in optional equipment, you will also need a jumper plug for the can lines if you do this from pin 1-6 and pin 2-5 to complete the can circuit. Otherwise you will get other codes.
  • Posted 17 Mar 2020 20:38
  • By Jezza_C
  • joined 17 Mar'20 - 1 message
  • Queensland, Australia
any sugestions
  • Posted 22 Feb 2020 19:13
  • By daniel_a
  • ARGES, Romania
Libiao Robotics
Michel Denis Michel Denis
