Won't move Forward or Reverse
I came back from Thanksgiving break and the forklift will not move in either forward or reverse. It will actually crawl a bit in both forward and reverse, but as soon as you give it any throttle you can feel the transmission disengage.
From some of my reading here it sounds like I need to at least start with draining the transmission fluid, and checking a screen at the drain plug. However, where is the drain plug, and is there a screen behind there? Also if I do change the fluid what fluid do I replace it with?
Any other help is greatly appreciated. If I need to I can post pictures, but did not see a link to do so. Thanks again.
  • Posted 4 Dec 2019 03:30
  • By Blue65
  • joined 7 Jun'17 - 7 messages
Owner of a Yale GLP060VXNVSE091
Are you seeing any codes on the display?
  • Posted 6 Dec 2019 06:29
  • By BREWSKI
BREWSKI
Toyota 8FG25
Terberg YT222
ROYPOW
Michel Denis Michel Denis
