Clark C500-25 s/n 235 615 3676 Wiring
I bet I'm going to regret working on this antique but I've started repairing a no-crank on a 70's (?) era C500. Some "mechanic" already replaced the key switch.
I can't be sure of the wiring on the anti restart relay or the key switch. Does anyone know how these old Clarks were wired? I used to know these things front to back but the only thing I remember from the 70's is that the solenoid "S" terminal got the orange wire. Well, not the only thing I remember; I remember the pachouli incense also but that's not going to help me wire this thing.
  • Posted 18 Sep 2019 09:40
  • By lumberjack
  • joined 27 Jul'07 - 183 messages
  • Maryland, United States
That's it. Thanks a bunch
  • Posted 19 Sep 2019 07:30
  • By lumberjack
I found my diagram. Terminal 1 goes to the starter solenoid. Terminal 2 goes to the neutral start switch. Terminal 3 goes to the alternator R terminal. If it has a fourth terminal that would be ground.
  • Posted 19 Sep 2019 04:00
  • By BREWSKI
BREWSKI
Yeah, the neutral start switch is ok. I've got B+ getting to the relay on start, I just wanted to confirm it was going to the right terminal. I seem to remember we had a lot of trouble with those relays.
  • Posted 19 Sep 2019 00:26
  • By lumberjack
First thing to check is the neutral start switch. it is in the side of the trans control cover. The starter solenoid wire runs directly through the switch.
  • Posted 18 Sep 2019 22:32
  • By BREWSKI
BREWSKI
Terberg YT223
Maxlion MTF25-60-2WD
