back up alarm. Raymond SA turret truck.
Anyone have advice about installing a back up alarm onto a SA raymond turret swing reach Model EASi swing Reach SN:SA-98-00100. Thanks for the advice.
  • Posted 22 Aug 2019 05:55
  • By Ibeam
  • joined 25 Aug'16 - 8 messages
If it's not in your Configuration settings. You might have to get a Raymond dealer to hook the laptop up to it with DTIC software. (Pre flashware) and turn that option on.
  • Posted 28 Aug 2019 07:17
  • By Service_T
  • joined 5 May'18 - 91 messages
  • Kansas, United States
ServiceT
Service_T hope your still watching this one. Wired in the back up alarm and went into configure mode and neither of my two SAs have alarm or EOA settings in the Travel configure areas. So I'm thinking its the Version. One is TM 4.02 ESA02.2 TS 00.3 with SN: 1835. What do you think. Im to a point, thinking about telling the operator to yell "beep.
Thanks again.
  • Posted 28 Aug 2019 05:41
  • By Ibeam
Good info. Got me started. Found JPS15 to be a 6 prong plug to TM, had to order, and k2 also didnt exist so ordered that because correct plug is in the harness for JPS15. Putting all of this on here in case anyone else runs into the same issue. Also a complete kit available, 838-010-476/002.
Thanks again Service_T
  • Posted 24 Aug 2019 04:12
  • By Ibeam
Use JPS15 5+ / 6- To activate K2 relay for negative signal from TP4.
Positive signal from FILT2 B+F1
Enable alarm through travel settings in Configure mode.
  • Posted 22 Aug 2019 12:32
  • By Service_T
ServiceT
SMV (Konecranes) 4632CC5
Taylor T520S
Taylor T520S
