ignition wiring diagram
I have just bought a GlC030 that I need to find the wiring diagram for the distributor and coil.
Someone has disconnected the wiring from the coil and distributor.
I am assuming that it is a Hitachi dizzy.
The distributor has a blue and a black/white wire.
The coil has a ballast resistor.
Any help or wiring diagram would be appreciated.
  • Posted 25 Mar 2019 01:44
  • By 1BobR
  • joined 25 Mar'19 - 9 messages
  • Kentucky, United States
Showing items 1 - 16 of 16 results.
Could I also get a copy of that wiring diagram for the GLC030AFNUAE082.?
mark @ mn-ice. com
  • Posted 23 Jun 2020 05:43
  • Modified 23 Jun 2020 05:44 by poster
  • By Mark_Lawson
  • joined 23 Jun'20 - 1 message
  • Minnesota, United States
For anyone reading this forum with the same problem.The Black/White wire from the distributor goes to the positive side of coil and the Blue wire goes to the negative side of the coil.
  • Posted 25 Apr 2019 23:43
  • By 1BobR
RedBull thanks for the help and thanks to everyone else that offered help.
  • Posted 24 Apr 2019 22:50
  • By 1BobR
check now I put the number2 instead of too
  • Posted 24 Apr 2019 15:51
  • Modified 24 Apr 2019 15:52 by poster
  • By redbull
  • joined 14 Oct'16 - 108 messages
  • Queensland, Australia
BigWahooToo(at)gmail(dot)com
  • Posted 23 Apr 2019 21:23
  • By 1BobR
No I don't see it. I checked my spam folder and it's not in there either.
email is [email address removed]
  • Posted 23 Apr 2019 21:19
  • By 1BobR
did you get email
  • Posted 23 Apr 2019 20:35
  • By redbull
check email
  • Posted 22 Apr 2019 06:59
  • By redbull
Yes I would appreciate a copy BigWahooToo(at)gmail(dot)com
Thanks,Bob
  • Posted 19 Apr 2019 22:34
  • By 1BobR
do you still need wiring diagram if so send email I have a copy
  • Posted 19 Apr 2019 06:24
  • By redbull
Thanks for the replies Swoop & Mrfixit.
I'm going to wire it up today and see what happens, hopefully I won't let the smoke out.
I've Googled every term. I can think of but haven't found a wiring diagram anywhere.
Thanks again Bob
  • Posted 3 Apr 2019 22:36
  • By 1BobR
I believe the 2 wires from the distributor just go to the coil. Blue on positive, black on negative, and then there should be a live wire (when the key is turned on) from the harness that also goes to the positive coil terminal also.
  • Posted 3 Apr 2019 21:27
i dont have any diagrams on that old of a model, maybe someone else can help out but the complete model and serial number is very helpful for anyone that can help. thanks
  • Posted 3 Apr 2019 14:21
I finally got back out to the property yesterday and loaded a 30 yard dumpster by hand. I hope I can get the forklift running for the next one.
The model of the forklift is:GLC030AFNUAE082.
The serial # is B809N02729Z.
Any help with wiring the ignition will be appreciated.
  • Posted 3 Apr 2019 00:35
  • By 1BobR
Thanks for the reply, I will get the rest of the required information.
I will have to get all the information next time I am out at the property, I had it all on my phone but of course my phone crashed.
It's a propane engine and I believe it is a Mazda.
Thanks again for your reply
  • Posted 25 Mar 2019 06:03
  • By 1BobR
need to know the full model number
what comes after the GLC030?
And a full serial number might be helpful also ;o)
Is it gasoline? LPG? Dual Fuel?
It's either gonna have a mazda engine or a GM.
Wiring color schema's change from year to year when they make model changes and depending on which engine is installed in it so the full model and serial number and engine make is necessary.
  • Posted 25 Mar 2019 02:18
Hoist Liftruck P360-48
UN Forklift FD35T-C2JB2
Esie Cortez Esie Cortez
