E152 on 2018 model
Check your battery voltage and battery water level. If voltage is good been finding the CAN bus wiring in the control handle is getting pinched between the control handle and the handle return spring cutting the CAN bus wires internally.
Action- Change out control handle wire harness.
  • Posted 21 Feb 2019 06:26
  • By tyler_d
  • joined 23 Sep'16 - 79 messages
THANK YOU.
WE FOUND THE SAME PROBLEM.
  • Posted 22 Jul 2020 22:46
  • By VIPER
  • joined 9 Feb'11 - 24 messages
  • FLORIDA, United States
