Crown SP 3500 raise switch fault
Hi,
im working on a crown sp3500 and cant find the source of this raise switch fault. upon start up after charging (or any time battery is reconnected to lift) i get the beeping and Raise Switch prompted on the display. i have already ohmed out and checked low and high speed switches and both test good. found fault code 435 and went through the test/resets and still no luck. if i let the lift beep away on initial start up it eventually clears the code and operates normally, even when keyed off and on again. i only have this issue when reconnecting the battery. Has anyone else experienced this issue, or maybe know what steps to take to repair? i have already gone through all of the service manual steps for trouble shooting code 435 with no success.
Thanks Blake
  • Posted 31 Jan 2019 06:01
  • By 1stRankinRepair
  • joined 31 Jan'19 - 4 messages
  • Arizona, United States
Thanks I'll give that a try.
  • Posted 14 Feb 2019 16:12
If you have another SP3500, swap the display panel.
  • Posted 31 Jan 2019 21:17
  • By Ifixit
Terberg RT403
Toyota 3FD100
Sue Tomic Sue Tomic
