diagnostic connector/ dash light blink
need help plz... working on a H80xm (2002) serial # K005V03542Z.this unit has a GFI OPEN LOOP SYSTEM SERIES with a 4.3 gm engine straight LPG.the diagnostic connector is flat 4 pin. wire#s are wore off as usual. what pins do I jumper. the service manual I have for the K005 has a closed loop system in it. any ideas ?
  • Posted 25 Jan 2019 02:38
  • By keith_m
  • joined 29 Jun'09 - 57 messages
keith@kmcequipment.com
keith check email wiring diagram
  • Posted 1 Feb 2019 18:33
  • By redbull
  • joined 14 Oct'16 - 108 messages
  • Queensland, Australia
thanks for your help. that was exactly what i needed.
  • Posted 1 Feb 2019 02:19
  • By keith_m
Should be pin a to pin b. Wire 466 to ground.
  • Posted 25 Jan 2019 06:35
  • By BREWSKI
