ALARM CODE-57 ON MOD #1
Hi, can someone tell me what is this error?
error comes out and forks get blocked.
Thank you in advance.
  • Posted 13 Dec 2018 07:46
  • By ale_r
  • joined 12 Oct'17 - 36 messages
hello , I don't know the voltage but the rest of the serial is 4NR3638703.
I will let the tech now so he can check what you just told me.
  • Posted 15 Dec 2018 03:14
  • By ale_r
can you get a full model number and serial number? and voltage of truck?
I did some checking on a 36v truck and error 57 deals with broken wiring in the auxillary hydraulic circuit.
You'll need to check the wiring in the mast cable, also pay attention to the connector at the base of the mast where the carriage side of the main harness starts, and even go out to the pentograph and check the harness running through it out to the forks and make sure it is not smashed or damaged.
  • Posted 13 Dec 2018 12:48
  • Modified 13 Dec 2018 12:58 by poster
Esie Cortez Esie Cortez
