crown sp3020-30 brakes won't release
Units brake doesn't release with deadman, tested brake module and all voltages on test points match those of table in service manual, replaced magnetic coil and brakes still don't release. Leaning towards brake module but not 100% sure. Tow switch doesn't even actuate magnetic brake. Any thoughts?
  • Posted 7 Nov 2018 07:29
  • By jack_d
  • joined 7 Nov'18 - 5 messages
  • Wisconsin, United States
Checked the upper gauge in brake assembly is correct
  • Posted 12 Jul 2019 06:27
  • By cesar_c
  • joined 12 Jul'19 - 2 messages
It ended up being the brake module, tested good at all test points and fault LED wasn't lit up but it wasn't actually outputting to the coil. Installed rebuilt brake module and it works perfect now.
  • Posted 20 Nov 2018 06:11
  • By jack_d
I will check that next time I am in there, thanks for response.
  • Posted 8 Nov 2018 02:54
  • By jack_d
Try checking CA209 on the dist. board, I've had pin 3 burn a few times in the past.
  • Posted 8 Nov 2018 02:08
  • By JMC1
  • joined 8 Nov'18 - 50 messages
  • Iowa, United States
Airman ENCL045
Aichi SR18A
Airman ENCL045
Aichi SR18A
