OVER HEATING IGNITION COIL
HI I NEED SOME HELP WITHA MITSI GAS MACHINE.6 MONTHS AGO IT WOULD NOT START AFTER INVESTIGATION FOUND FAULTY COIL AND PICKUP IN DISTRIBUTER.REPLACED BOTH AND TRUCK RAN FINE.3 MONTHS LATER SAME PROBLEM SO I FITTED THE SAME PARTS ONLY AFTER TESTING MACHINE FOUND IGNITION COIL GETS VERY HOT.I CHECKED CONNECTIONS TO COIL AND BALLAST RESISTOR THEY SEEM FINE CANT SEE ANYTHING ELSE WRONG.ITS STARTING TO GET COSTLY TO REPLACE PARTS SO ANY HELP WOULD BE GREAT.
  • Posted 10 Jul 2008 02:12
  • By Mag1
  • joined 24 Feb'06 - 25 messages
  • CO DUBLIN, Ireland
check that the voltage is completely shutting off to it so that the coil isnt getting power when it shouldnt be
  • Posted 12 Jul 2008 12:14
  • By justinm
it the alternator overcharging?
resistance on the harness or loose connections?
check the frame grounds etc
  • Posted 12 Jul 2008 11:56
  • By justinm
Kai von Berg Kai von Berg
UN Forklift FGL18T
Toyota 8FD45
Bolzoni SpA (Group HQ)
