No Dash Display
A908N06673E
Has anyone had this issue?
Turn key on, dash flashes on for 2 seconds then goes out. Machine overall works as it should. Both AC controllers show no codes on LED indicator. I swapped display with a known good one but same results. I checked all wiring and connections , I suspect the dash is controlled by the master controller?
  • Posted 10 Aug 2018 22:58
  • By BrewCrew
We`re here for a good time
Yes very odd,I do have constant power on the brown\white and ground on the black at the display. So the conclusion is a faulty master.
Thx for the info BREWSKI
  • Posted 11 Aug 2018 01:57
  • By BrewCrew
yes it is. It is odd that it comes up then goes blank. The display communicates with the master controller through CANBus. My guess is there is a problem with the Master controller. The display has a positive and a negative supply all the time if the battery is plugged in. You could check to be sure you have both. I would think the truck would fault out if you lost power to the display.
  • Posted 11 Aug 2018 00:23
  • By BREWSKI
Taylor XC300M
New - Sale & Hire
Manitou M50-4
