Code 1:580
Unit won't take log-in. Operator code... then enter... and all you get is a beeeep and a circle with a line through it on the CID.
Prior to that in code history also code 3:332 - which isn't in my manual, but as of right now I cannot start unit in emergency mode or any mode.
  • Posted 22 Jun 2018 01:58
  • By UncleSi
  • joined 12 Feb'13 - 135 messages
  • Manitoba, Canada
Thanks for the help/tip.
  • Posted 19 Jul 2018 02:37
  • By UncleSi
  • Manitoba, Canada
Hi, Just I am giving some more hints for errors 1:580 & 1:581.
Whenever above errors on the display, Just switch on the machine with emergency mode & Switch off the machine, Then switch "on" in normal mode, Your problems will solve, We do many times.
Just as a Masala/ Salt for your problems,
Good luck.
RGDS.
  • Posted 11 Jul 2018 14:39
  • By gopal_s
  • joined 29 Oct'12 - 156 messages
  • karnataka, India
GOP
So this deal started out with Code 1:580. Took the fuse box apart, everything "looked" like brand new (but it is a printed circuit board and I'm no rocket genius so ???). Put the fuse box back into unit and it starts up?? BUT - now that the unit will fire up - we move on to the other code 3:332. Long story short I replaced the ACT and it's back up running again. Wish machines didn't spit out Codes that aren't in the manual, and maybe I don't have the most up to date manual??
I fear the 3 new units we are about to receive will have me leaning heavily on dealer support as they seem to get more and more "proprietary" in terms of info and manuals.
We shall see. Thanks for the help, once again.
  • Posted 6 Jul 2018 02:59
  • By UncleSi
  • Manitoba, Canada
Thanks.
Took the fuse box out and took it apart. Key relay looks perfect certainly not welded, actually has some continuity issues ( in my feeble diagnostic mind) in the printed circuit board from the key relay to the spade terminals that the harness plugs into. One side is "open".
Ordered a new fuse box and hopefully that will fix that, then I will move on to the other codes if still present. Unit is dead in the water until I can at least start it back up.
19000+ hours - she's no spring chicken.
  • Posted 22 Jun 2018 23:57
  • By UncleSi
  • Manitoba, Canada
1:580 = K20 Key relay contacts welded.
3:332 = ACT did not respond during start up.
Check fuse F73 isn't blown.
  • Posted 22 Jun 2018 19:37
  • By Forkingabout
  • england, United Kingdom
