lack of power
I have inherited a service problem, my customer has a Cat GP18K forklift with very low power, its an LPG engine, it stars instantly, tick over is smooth and quiet, but when the accelerator is pressed very little happens. when you engage drive in either direction it barely moves. I have never dealt with lpg systems before so any help would be appreciated. it has an Impco model 100 gas control unit (not sure what its called)
cheers in anticipation zzzzzzzz
  • Posted 8 May 2018 04:09
  • By eestibob
  • joined 8 May'18 - 2 messages
  • voru, Estonia
so after replacing spark plugs and leads, fuel lock and regulators I found the fault. it was the choke which was jammed shut due to a broken piece which was holding it closed. after removing and repairing the choke everything is good, except the bank balance.
  • Posted 22 May 2018 14:23
  • By eestibob
  • voru, Estonia
UN Forklift FGL25T
JCB 533-105
