Veracitor 40VX fault 524230-3
anybody know the fault code 524230-3 and how troubleshooting
  • Posted 2 May 2018 06:18
  • By DamianL
  • joined 2 May'18 - 2 messages
  • Colorado, United States
Just wondering if you found a fix to this problem?
Having the same issue
  • Posted 26 Jun 2018 09:03
  • By forktime
  • joined 22 Dec'17 - 31 messages
  • Alberta, Canada
DTC 524230-4 - Rear Work Lights Relay (RL7) Driver Output OORL
A. SHORTED RELAY COIL
B. SHORT TO GROUND ON PDM RELAY DRIVER OUTPUT
C. FUNCTIONAL FAILURE IN CONTROLLER
524230-3 Rear Work Lights Relay (RL7) Driver Output OORH
A. SAFETY SWITCH (IF EQUIPPED) IS DISCONNECTED
B. SHORT ON RELAY DRIVER OUTPUT TO UNSWITCHED BATTERY (SEE WARNING BEFORE CONTINUING)
C. SHORT ON RELAY DRIVER OUTPUT TO SWITCHED BATTERY. D. SHORT ON RELAY DRIVER OUTPUT TO ANOTHER OPERATED DEVICE
E. CONTROLLER DRIVER OUTPUT TO RELAY COIL OPEN CIRCUIT F. RELAY COIL OR GROUND CONNECTION OPEN CIRCUIT
G. FUNCTIONAL FAILURE IN CONTROLLER
  • Posted 2 May 2018 22:16
  • Modified 2 May 2018 22:18 by poster
  • By BREWSKI
Komatsu FD25T17
SMV (Konecranes) 4632CC5
