Crown WAVE
For some decades I have collected and organized technical info on various crown equipment including WAVE.
Contact my profile to share detailed troubleshooting info.
  • Posted 8 Apr 2018 05:12
  • By tom_p
  • Alberta, Canada
I got a wave 50 code 7.. I'm not getting foot sensors to open and close I check with handset.. but switch tested good I'm thinking possibly display module ?
  • Posted 20 Jul 2024 12:19
  • By Wattscrowntech
  • joined 7 May'24 - 4 messages
Daniel
Could it be one of the EPO, like the one on the bottom panel?
  • Posted 1 Sep 2022 20:23
  • By Fixit
  • joined 27 May'21 - 8 messages
ChrisB
I had a wav 118-60 that wouldn't power up. When you turned the key on the display or battery meter wouldn't light up. I checked fuses, plugs, power to the contactor and controller but it just wouldn't power up. I don't have access to Crown manuals so I told the owner to get a Crown tech in. He did they used an analyzer worked on it for 8 plus hours. They came to the conclusion that it needed a new wiring harness. Could it be the contactor for the hydraulics?
  • Posted 2 Apr 2022 12:00
  • By BigAl73
  • joined 9 Aug'19 - 18 messages
  • Posted 2 Apr 2022 11:56
  • By BigAl73
428 is mismatch of traction pot and motor speed. Can you drive normal with the platform down? Does it only cut out if you raise to a certain point? That would point me to the mast cables.
  • Posted 25 Feb 2020 09:34
  • By Ifixit
Hi Tom
I have a WAV60-118 (yr 2016) in trouble cutting out when driving with the forks raised.
following codes are displayed 312 233 428
we suspect damage to wiring loom in mast?
can you shed any light on this.
if it is a controller problem will we need engineer access codes/ hand held controller to set up the new controller
thanks in advance
  • Posted 24 Feb 2020 22:35
  • Modified 24 Feb 2020 22:35 by poster
  • By gussy78
  • joined 2 Dec'14 - 13 messages
  • Ireland, Ireland
Combilift Ltd
Deborah Baker Deborah Baker
