No Start
I just replaced the fuel filter element on this lift and did a service...after buttoning it back up and trying to start it to re-learn the FCM The lift pulled up an AD-1 code and will not start. I tried to reset the Code by unhooking the Neg. Battery terminal for more than 10 seconds and also referred to the manual and all it says is that either the CAN communication 4Y-ECS data reception error...so now I don't know where to go from here...is there a way to master reset this? Hard to believe that a new filter would cause this much of a headache...any input would be MORE than greatly appreciated
  • Posted 15 Feb 2018 07:30
  • By Tech1Lift1
  • joined 10 Oct'17 - 4 messages
  • Minnesota, United States
Around the fuel filter area are some harnesses and plugs which may have broken or loosened when the filter was changed.
  • Posted 18 Feb 2018 12:59
  • By tom_p
  • Alberta, Canada
Sue Tomic Sue Tomic
Hangcha FLDCXT160
Aichi SR18A
