Lp Gas leaking out of air filter E21, E23
Hello, I'm having fault codes E21 and E23 on 2008 C5000 forklift. I noticed LP gas starts to leak out of air filter when ignition is on. This forklift has Nissan K25lp engine.
Wondering if anyone has experienced such problem?
Also I'm looking for service manual for this forklift?
  • Posted 30 Jan 2018 06:29
  • Modified 3 Feb 2018 02:38 by poster
  • By Atlantis
  • joined 30 Jan'18 - 5 messages
  • Illinois, United States
Hard Core
Hey Kevin, are these parts you have listed here for 2008 C5000-LP?
  • Posted 3 Feb 2018 02:43
  • By Atlantis
Hard Core
The vaporizer is available new and reman from you local Cat dealer as well as all of the parts to rebuild. If you have not rebuilt one of these before I would suggest going with new or reman version. The reason for this is the vaporizers on these trucks have changed several times over the years and take different components and if you do not know which one you have you may not be getting the correct components.
  • Posted 30 Jan 2018 23:04
  • By Partsguy5
Your LPG fuel injector can also leak fuel past it. Normally if you have a leak from your vaporizer it will be coming through the small vacuum hose from the vaporizer to the air horn on the mixer.
  • Posted 30 Jan 2018 16:13
  • By mwjski
  • joined 26 Jan'18 - 33 messages
  • Montana, United States
Thanks Kevin...You made it even easier
  • Posted 30 Jan 2018 10:32
  • By Atlantis
Hard Core
Screw kit 16065-GY010
Nissan Valve 17962-FU460
CAT CT91H2004460
Diaphram Secondary 17054-FU460
Diaphram Primary 17960-VR500
Diaphram (small) 17053-FU460
O Ring Kit 16328-GY010
Looked thru mmy old notes and foundnthe part numbers and such for rebuilding the NIKKI Regulator...these are Nissan numbers butnwill work on the CAT ras well...there is one CAT part number for the valve
  • Posted 30 Jan 2018 10:14
  • By kevin_t
Thanks
  • Posted 30 Jan 2018 09:23
  • By Atlantis
Hard Core
Not sure how Cat sells their regulators. If this is not emission compliant you can get a repair kit for the regulator.
  • Posted 30 Jan 2018 09:22
  • By BREWSKI
....Make sence, do you know if this part sold separetly?
Thanks anyway.
  • Posted 30 Jan 2018 08:52
  • By Atlantis
That is usually a blown regulator/vaporizer.
  • Posted 30 Jan 2018 08:28
  • By BREWSKI
Hawker Powersource, Inc.
Oxford Ct, United States
Esie Cortez Esie Cortez
