Remove tilt cylinder
I am trying to remove the front pin on the left side tilt cylinder. There is no way to drive the pin out, because the inside end of pin is blocked by the mast. Anyone know of a tool or technique to ease the removal of this pin?
  • Posted 29 Jan 2018 12:20
  • By glenn_j
  • joined 29 Jan'18 - 3 messages
Got it. Man I sure do appreciate your help. Have a good one.
  • Posted 2 Feb 2018 14:28
  • By glenn_j
They are not the only ones. Have you loosened the clamp bolt on the yolk? This will make unscrewing the ram a lot easier.
  • Posted 31 Jan 2018 00:26
  • By BREWSKI
BREWSKI and Mrfixit, thanks for your responses. Unfortunately the pin does not have the threaded hole in the end of it. I attempted to unscrew the shaft, but it is extremely tight. I will go back and try this again. In the meantime, if anyone has other suggestions, please let me know. I cannot believe Clark designed this lift in a way that the pin can't be driven out.
  • Posted 30 Jan 2018 23:43
  • By glenn_j
The end of the pin may have a threaded hole in the center to screw a bolt into to help pull it out.
  • Posted 30 Jan 2018 07:03
You have to remove it from the inside out. The second option is to unscrew the ram from the yolk and remove the cylinder.
  • Posted 30 Jan 2018 00:48
  • By BREWSKI
Taylor TXB180S
TCM FD115-3
Hyster
Hyster
