Torque specs for the head
I have a K25 Nissan engine and I need the torque specs for the head on this engine. I would really appreciate it if someone has the numbers.
  • Posted 9 Jan 2018 02:18
  • By easymo
  • joined 20 Oct'17 - 6 messages
  • Michigan, United States
Thank you for the info. Much appreciated
  • Posted 10 Jan 2018 01:46
  • By easymo
if you are just checking the torque on the bolts then the end torque spec is 19.6 - 23.52 N.m (2.0 - 2.3 kgf-m) plus 90° which should wind up being around 68.6 N.m
If you are installing new bolts or a new head then there is a sequence and method you have to use when installing a new head.
Use new bolts!
There is a tightening and breakin torque, return to 0, then final torque
step1 = 19.6 - 23.52 N.m (2.0 - 2.3 kgf-m)
step2 = 68.6 N.m (7.0 kgf-m)
step3 = 0.0
step4 = 19.6 - 23.52 N.m (2.0 - 2.3 kgf-m)
step5 = 90° - 92°
perform step 1, through all bolts
then do step 2 and run engine till hot.
let engine cool down
do step 3
then step 4 and 5
as for the tightening pattern you start in the middle bolts then work your way out using a cross hatch pattern for the next set, then the outside bolts reverse the cross hatch pattern.
If you contact me via the email address in my signature i can send you the diagram for this proceedure if you are unsure.
  • Posted 9 Jan 2018 10:47
Crown CG33P5
Airman ENCL045
