drive problem developing
this problem started 5 weeks ago and is gradually getting worse. after start up , release parkbrake ,select drive then press pedal you only get slight creep in either direction. on /off cycle clears fault for a couple of days !!!. no fault codes on screen though, could this be brakeswitchs starting to playup
  • Posted 27 May 2008 05:56
  • By kevin_k
hook up lap top , cant think of what program to go to , but wheels should start turning at 460 mille amps. program is in pathfinder
  • Posted 22 May 2015 12:06
  • By edward_m
  • joined 11 May'15 - 111 messages
herald my friend. you confirmed my suspicions. laptop would save a lot of time. if i can,t test it out with my meter i,ll recommend to customer to get linde into the truck. won,t waste my time and their money. regards
  • Posted 3 Jun 2008 06:41
  • By kevin_k
Hi kevin some fault codes don,t show up on the display but only in the truck memory accesed by the lap top,which you don't have,i have had this before but not intermittant and yes it was the brake switches,if you can get it to do it look on the display and see if the parking symbol stays on when the brake is released this would suggest a badly adjusted or faulty switch.
  • Posted 1 Jun 2008 07:29
  • By Herald
  • joined 3 Jan'07 - 128 messages
  • lancashire, United Kingdom
Terberg YT223
Aichi SR18A
Terberg YT223
Aichi SR18A
Bolzoni SpA (Group HQ)
