FAULT CODE 5G? EC15KS
Hello guys,
We are having trouble with this unit, I can't find anything related with this 5G code,
The machine when going forward the speed is not consistent it decelerate and accelerate (jerking)
There's no problems going on reverse.
Technician told me that the unit is showing up a "5G" CODE.
Any ideas?
  • Posted 17 Oct 2017 00:44
  • By MisterMechanic
  • joined 17 Oct'17 - 1 message
Mr. Mechanic LTS
I had a couple of these in my fleet a while ago. The 5G/5H codes usually occured when the battery voltage was low. Making sure your battery has a good charge and is watered is the first step. I moved the power cables away from the traction amps control wiring. (Inside the battery compartment behind the traction motors) There isn't that much play in the cables. But that helped with the interference.
  • Posted 8 May 2018 13:17
  • By Service_T
  • joined 5 May'18 - 91 messages
  • Kansas, United States
