lift,reach, shift sometimes wont work
I have a lift here that has been causing some issues. some times it wont lift, then maybe it wont reach, next time it may not shift or all of the above at the same time. let it sit awhile it will all start working for awhile then starts all over again. aux pump was replaced a little over a year ago. could it be the pump again and its losing pressure?
  • Posted 11 Oct 2017 08:11
  • By fathead05
  • joined 20 Sep'16 - 2 messages
Sometimes it wont lift, what happens...no lift at all, or hesitates. Does the pump run but no lift or just no sound at all? How old is this>>>what ser. #
Older models were bad for guts of free lift cyls going into hyd manifold and causing lots of issues. Raymoan!
  • Posted 11 Oct 2017 21:59
  • By EasiTek
