Code 209L
We have a 3 wheel hyster electric showing code 209L at start up. brake is new and the strange thing is that after start up if you unplug fuse #14 which is wire 10 into C3 position in controller and immediately plug fuse back in, truck will run all day until you shut off key switch. We have installed 2 different r/b controllers from flight systems as well as local dealer has let us take a controller from their shop out of a known running truck and all 3 have same issue and results. Zapi controller #FZ5017C ser #539443 417-2
Dealer tech as well as our techs have spent days on this truck and all leads to being controller issue, but I find that hard to believe with 3 different units installed
  • Posted 31 Aug 2017 01:04
  • By reithind
  • joined 25 Oct'12 - 1 message
Run a check on the left hand motor encoder, I have had the same problem and the encoder was at fault. Even if the encoder checks good I would replace it.
  • Posted 31 Aug 2017 22:48
  • By BREWSKI
Deborah Baker Deborah Baker
VETTER Industrie GmbH
