ACP 20 forklift
This is my first time using this forum. Don't know if this question should be in the technical forum. I have an old Allis Chalmers ACP 20 forklift. LP SERIAL ADD 89370. I can't find an operators manual anywhere. There is a dipstick for the engine oil and one for the hydraulic oil. I can't find one for the transmission. Does the hydraulic oil also flow through the transmission? What hyrraulic oil does this machine use. A tractor dealer told me it takes Mobilfluid 424 which I can't locate. Also, what engine oil does it take. Sorry for so many questions but any help will be appreciated.
  • Posted 12 May 2008 05:58
  • By Marblecarver
  • joined 12 May'08 - 1 message
  • Louisiana, United States
John Colligan
I believe that unit does have the trans and differential filled in the same place. Would need to know the year to be sure. An easy way to check is look for a plug in the front of the differential for adding fluid, if so it is not trans fed. Also if you have internal brakes it is usually trans fed.
  • Posted 13 May 2008 03:46
  • By JDBurton
  • joined 4 Jul'07 - 96 messages
  • Virginia, United States
JCB 533-105
SMV (Konecranes) 4531CC5
