The machine will raise the tower great, but will not lower or has difficulty lowering
I've checked the mast and it's components multiple time. Everything on the mast has been checked. The cylinder, the flow back control, the cable, everything.
There is not obstruction because I took everything apart, checked and cleaned it.
Everything works just fine, except when I have to lower the last it taste time and does so extremely slowly, if at all.
The worst part is that it doesn't give me a code at all.
I am at my wit's end and would love if someone were to assist me with this.
Could the middle cylinder be bent? Please share your thoughts and experiences.
Thank you all.
  • Posted 18 Jul 2017 03:41
  • By victormc
  • joined 18 Jul'17 - 2 messages
E.C Equipment Services
30 years strong and growing in South Florida.
I see that it's been some time but what was the solution to this issue. I'm currently dealing with this exact issue on the same type of unit. I've checked and cleaned all passageways, valves and filters. The mast slowly drops about 3/4 of the way down then stops all together.
  • Posted 26 Aug 2025 04:04
  • By Antho_Tum
  • joined 26 Aug'25 - 1 message
I think this truck has a flow control valve in the block that the feed hose attaches to. I would recheck that valve. If it is good you might have a defective feed hose or a problem in the control valve, maybe a piece of debris. I have had hoses cause this problem also.
  • Posted 18 Jul 2017 22:18
  • Modified 18 Jul 2017 22:19 by poster
  • By BREWSKI
It does so when pulling the lever down from any height. It goes up perfectly, but when the lever to descend is pushed up it will either stop and cease moving, or it will go down very very slowly. It is as if there were something obstructing the oil flow from the cylinder back into the machine.
Thank you for the quick reply.
  • Posted 18 Jul 2017 08:23
  • By victormc
Does it slow down at a specific height or is it all the way down?
  • Posted 18 Jul 2017 07:14
  • By BREWSKI
SMV (Konecranes) 4632CC5
UN Forklift FD50T-NJB3
ROYPOW
