No Start
4.3 Propane. Won't start. Codes 100-3, 522740-5, and 522739-5.
Cranks but won't start, locks out and then throws the code. Disconnected battery to clear code, still no start. Changed propane tanks , same result.
Only 300 Hrs on Truck.
  • Posted 6 Jun 2017 10:33
  • By Ironmikeww
  • joined 6 Jun'17 - 4 messages
  • Washington, United States
jmklitzke
What you are asking for is available from your dealer. You need a wiring diagram and a service manual.
  • Posted 14 Jun 2017 22:40
  • By BREWSKI
After installing new Oil Pres. switch and a no start, I began to check fuses again. I swapped relays and it started. Went to a local dealer and replaced the defective one and it runs fine. It would sure be helpful if Hyster would give out some info about what fuse or relay controls what.
  • Posted 14 Jun 2017 07:46
  • By Ironmikeww
yep that warranty went bye bye long ago, even the warranty you get when buying a used machine is gone so you're on your own with this one. i just thought it was worth mentioning because of the hours, glad we got that cleared up ;o)
just fyi, todays warranty's are 2yrs now with a 5yr powertrain, with some mfg's on new machines. If there is any doubt it always pays to call the dealer and have them check.
  • Posted 8 Jun 2017 22:25
Can tell you now being that its a 2009 there wont be any warraty covergage on the truck......warratys on forklifts arent the same as on cars and trucks...at best you might get a three yr warranty but is usually way less than that...
  • Posted 8 Jun 2017 09:46
  • By kevin_t
Had the truck since 2012, it is a 2009, had 56 hours on from new. I'll call the dealer in the morning.
  • Posted 8 Jun 2017 09:21
  • By Ironmikeww
yeah i was thinking the same thing as kevin is
UNLESS the truck is less than a year old, THEN it might be a warranty issue and yes call the dealership and have them repair it.
just call their service department, have them check the serial number to see if it is still under warranty.
  • Posted 8 Jun 2017 07:19
  • Modified 8 Jun 2017 07:20 by poster
Just because the hour meter reads 300 hrs dosent mean it acrptually has three hundred hrs...also it can have three hundred hrs and be ten years old so hrs isnt to much of a foactor..lhow OLD is the machine and how often does/did it get used?
  • Posted 8 Jun 2017 07:16
  • By kevin_t
Replaced the oil pressure sensor. no start. Checked for spark, no spark. Now what. Wiring at the OP switch seems ok, only 300 hrs on machine. Do I call Hyster?
  • Posted 8 Jun 2017 04:55
  • By Ironmikeww
the oil pressure switch is what's keeping it from starting up
but as kevin said, make sure you address the O2 sensor problem, these will effect performance
  • Posted 6 Jun 2017 21:24
The 522739-5 and 422740-5 codes are for open circuit for the heater circuit on the oxygen sensor(s).....the 100-3 is for oil pressure switch out of rnage,high(OORH)....check wiring and fusing for oxygen sensors...also check wiring for oil pressure switch
  • Posted 6 Jun 2017 15:04
  • By kevin_t
Kai von Berg Kai von Berg
Morooka MFD20
Terberg RT223
