Nichiyu FB15PN-DC70C-400
Hi everyone, My forklift displays error 'A10: FET7-OVER DRIVE & D24: PC.BOARD AOS'. This forklift don't move and lift. May you help me?
Thank you in advance for your help,
  • Posted 19 May 2017 14:13
  • By minh_d
  • joined 13 Jul'15 - 17 messages
  • Ho Chi Minh city, Viet Nam
duongminh6989@gmail.com
Hi Marcb, i have a problem with this forklift. The thing is, i changed the mpu board as it was damaged. With the new board i set all the options as required in the manual and the problem i get with, is that i cannot set the starting current ant current limitation. Thank you in advance for your thoughts!
Serial nr.:226DC2180
  • Posted 19 Dec 2019 17:13
  • By Buitweedas
  • joined 3 Dec'19 - 4 messages
  • Lithuania
Hey Ouano, I think that you're having a battery problem or a bad connection somewhere. Attach a voltmeter on the battery and start the machine up. I guess you will see the voltage going up and down at that moment.
Marcb
  • Posted 7 May 2018 02:15
  • By marcb
  • joined 10 Jun'14 - 221 messages
  • ANTWERP, Belgium
Hello Mr Marc,
Good day!
I have NICHIYU FB15PN-DC70-300, when i turn switch on there is no display in display panel of forklift, the power relay keeps on vibrating and you can hear an abnormal noise. The main contact doesnt come in but no digit visible. In MPU board i see only redlit in p12. No function in all. What should we do.? Thank you so much in advance.
[email address removed]
  • Posted 2 May 2018 10:44
  • By Ouano
  • joined 11 Nov'15 - 4 messages
  • muntinlupa, Philippines
Hello! I have the same problem, I give the contact and nothing works. Only the power steering engine works. Three red LEDs on the control unit. Sometimes the main engine contactor comes in, but it hits a lot of sparks and just a little tug. In addition, the display can not be seen, only green lights are lit in the display but no digit is visible. What should I look to solve the problem? Thanks in advance.
  • Posted 11 Jan 2018 08:23
  • By jero_m
  • joined 2 Feb'14 - 7 messages
  • jaen, Spain
Hey Marcb, I got it. Thank you very much.
  • Posted 20 May 2017 02:13
  • By minh_d
Hey Minh, I think someone has changed the option setting of the machine. Please control the option setting by putting RS1 (on the main print card) to 7, switch on the contact. The 2th and 3th number starting from the left side must be on 0 and not on 1. if you need to change that number, use the M button to go to the next number and + or - button to change the value. Switch the contact OFF and change the RS1 back to O, switch it back ON and see what the result is.
Regards
Marcb
  • Posted 19 May 2017 23:18
  • By marcb
  • ANTWERP, Belgium
Maxlion FD25
Ncn 110TH
Ncn 110TH 2015
